20
Before you click away, this isn't the typical "how do I make my bash prompt have color" question. I've already customized my bash prompt to look like this:
[user @ host]----[$(pwd)]
where everything in brackets is light blue, and everything else (including $) is black by adding the following to my ~/.bashrc file
# Turn the prompt symbol red if the user is root
if [ $(id -u) -eq 0 ];
then # you are root, make the prompt red
    PS1="[\e[01;34m\u @ \h\e[00m]----[\e[01;34m$(pwd)\e[00m]\n\e[01;31m#\e[00m "
else
    PS1="[\e[01;34m\u @ \h\e[00m]----[\e[01;34m$(pwd)\e[00m]\n$ "
fi
The goal is to make it such that the only thing that changes when I use 'sudo su' is that the black $ changes into a red #. I've looked in /etc/bash.bashrc and /etc/profile to see if there is just a line to comment out, but there is a bunch of stuff about debian_chroot that I don't understand, and I don't want to screw something up. How can I accomplish what I want?
P.S. This is what I want the prompt to look like as root
(red)#
edit: Mark this solved, appending the above code to ~/.bashrc while root accomplished my goal. Also, in the above code, $(pwd) only displays the home directory (I guess because that is the working directory when the terminal is opened), and never updates. Replacing $(pwd) with \w fixes this, but displays the home directory as ~, which I was trying to avoid.
zmitchell
  • 303
5 Answers5
13
It will also depend on how you become the root user. You need to make the change in the root user's .bashrc if you are using something like su - root or sudo -i, where you read in the environment.
With sudo -s, you should be reading your own .bashrc.
Consider adding some printf or echo statements to debug your code, to tell you when it has executed.
Use the id command to make sure you are who you think you are:
root@tau:~# id
uid=0(root) gid=0(root) groups=0(root)
belacqua
  • 23,540
Following belacqua's valid answer https://askubuntu.com/a/305053/12218, by issuing sudo su the root's .bashrc is loaded.
You can check this by issuing sudo su followed by cd ~ you will see that you are at root's home directory.
Using sudo su you log in as root (su = switch user) in contrary with
sudo do some administrative task as user with elevated privileges.
So by using sudo su you become the actual root and the changes made to environment are changes made specifically to root, i.e: sudo su followed by vim .bashrc.
Stef K
  • 4,886
To change the colour of the prompt to red for root, I modified the .bashrc file, following the examples in this thread.
regularuser@myubuntubox:~$ sudo su -
root@myubuntubox:~# vim .bashrc
Then, in vim, search for the final appearance of PS1 assignment, and add this following it (note that it updates the value of $PS1 so that other previous lines do not need to be modified, and the change is easily revertible):
# Set RED prompt
PS1="\[\e[01;31m\]$PS1\[\e[00m\]"
CJBS
  • 181
Following may help
export PS1='`[ $(id -u) == "0" ] && echo "#" || echo ">"` '
This will show '> ' for normal user and '# ' for root. This still needs to be in root's .bashrc too.
as others said previously in this topic "su -" and "sudo -i" or "sudo -s" using the .bashrc from /root directory so you should add to the end of /root/.bashrc file. I just write a sample my be it could make this easier for newbies.
# enable color when you login as root user with sudo -i or sudo -s
# this is just a test and I'am not sure if it works well
if [ `whoami` == 'root' ]; then
        # Set RED prompt [\033[01;31m\]
        PS1='${debian_chroot:+($debian_chroot)}\[\033[01;31m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
        # Set GREEN  prompt [\033[01;32m\]
        PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
fi
