I was looking for a dark theme to install and came across this page. I followed the instructions to install the Trevilla-Icons and Trevilla-Jmhzone-Dark Theme, but I can't select them on the appearance settings under themes it doesn't show up, Am I going about selecting the theme all wrong? I've never installed themes before so I'm a bit lost.
Asked
Active
Viewed 600 times
After it has installed, you can install something like Ubuntu Tweak to change your theme using these commands:
sudo apt-add-repository ppa:tualatrix/ppa
sudo apt-get update
sudo apt-get install ubuntu-tweak
After installation, open Ubuntu Tweak, then select the Tweaks Menu, then select the Theme Menu. The theme should appear under the Gtk Theme Menu or another similar menu.
Kupiakos
- 2,127
