-1
W: Failed to fetch http://ppa.launchpad.net/s-elser/winelol/ubuntu/dists/raring/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/s-elser/winelol/ubuntu/dists/raring/main/binary-i386/Packages  404  Not Found
Lucio
  • 19,191
  • 32
  • 112
  • 191
I would of thought that the PPA errors could not be obtained as they could possibly be outdated or some other issue as they cannot be located.
According to this website you can fix these errors by using sudo gedit /etc/apt/sources.list to edit the sources list file. Once you are in the sources file you can search for the PPA sources and check if they have been setup incorrectly for some reason.
If this fails you can also try cd /etc/apt/sources.list.d and then check the individual files from there using a text editor (I prefer using nano for this).
I have not used these methods before so I am not too sure if they would fix your problem. These methods seem like they will just check if someone has done some editing to the sources or added the sources incorrectly, I am not too sure what else you could do to fix the problem if the above methods fail.
I hope these suggestions help you.
jkrix
  • 68
I think the error is caused because the software sources that allow your computer to download updates and other softwares are not set properly.
You might want to open Ubuntu Software Center, go to Edit -> Software Sources and try changing/adding the ppas from where you are currently downloading the updates. You might also try changing the server from where ubuntu tries to install the updates by default.
As far as the 404 error you receive here is concerned. The ppa you are using doesn't currently host any packages for raring. Check this link.
