38
Has anyone managed to install OS X Guest in VirtualBox under Ubuntu? I've wasted 3 days trying to accomplish this by following various tutorials around the Web, but none seem to work for me.
Can anyone share some experience, or an updated tutorial link for this? For the record, I'm running Ubuntu 13.04 on Acer AS5830TG.
I will warn you that I do not condone this, so please don't try it. However, for educational purposes, it is possible to install OSX in VirtualBox... you need a Hackintosh install disc to do this though. For information on this, have a look here: Lifehacker "How to Run Mac OS X Inside Windows Using VirtualBox". Ignore the fact that they are using VirtualBox in Windows, because the same process will work in Ubuntu too.
Smile4ever
  • 1,091
hazrpg
  • 972
http://www.sysprobs.com/install-mac-snow-leopard-1063-oracle-virtualbox-32-apple-intel-pc Should work on ubuntu as well, give it a try
I have done the same thing and found out that OSX is very hardware specific. So to get the OSX to work you need to adjust the OSX to understand the hosts hardware emulation. You will be able to get it up and running so that the ethernet works and the screen and the rest is very dodgy.
The other problem as that the OSX will not be update-able. As soon as you update the OSX the install will break. The process is a cat and mouse chase of ensuring your updates do not kill the emulators limited hardware.
You'd think that Apples decision to go down the Intel route would make it easier but it doesn't. In the end the emulation will be slow and any advantage that OSX brings will be lost.
There are premade versions that are sold by third party vendors to run on regular hardware but they too will suffer from the issues I have mentioned.
Meer Borg
  • 5,003
