11
for the moment I'm downloading torrents via magnet sing Transmission, when the first time I was asked by chromium to open the magnet URL, I choosed Transmission and I checked the Remember my choice for all links of this type.
Now I want to change the default torrent program for Magnet URL I want to open them using KTorrent.
How can I do that ?
Croviajo
  • 1,164
5 Answers5
A few things from this thread:
Chromium - or any other browser - doesn't choose which application to use for launching any external application. It relies on the OS for that.
You can use gvfs-mime to reconfigure it again if you need to change your previous setting
gvfs-mime --set x-scheme-handler/magnet KTorrent.desktop
NB: KTorrent must be available. For me I use deluge so my command uses deluge.desktop which was available in /usr/share/applications/
Hope this helps out.
David Lartey
  • 1,617
You can use gio mime (gvfs-mime has been deprecated)
To change the default to K-torrent
gio mime x-scheme-handler/magnet ktorrent.desktop
Mr.Turtle
  • 131
another option is to try to change this through the torrent client settings, e.g in BitTorrent press the settings icon on the middle right, then simply click associate with torrent files worked like a charm..
You need to change the "Handlers" setting. From this page:
  1. Click the Chrome menu on the browser toolbar.
  2. Select Settings > Show advanced settings.
  3. In the "Privacy" section, click Content settings.
  4. In the dialog that appears, find the “Handlers” section. Click Manage handlers.
  5. Use the drop-down menu next to a listed protocol to select the web service that should be used by default.
If that doesn't work then you can try deleting the correct line from the state file. Instructions here shold help get you started, there for google-chrome, but should be close enough. You basically find the line in your state file, delete it, and that makes the popup show again.
coteyr
  • 18,724
You can use xdg-mime:
xdg-mime default KTorrent.desktop x-scheme-handler/magnet
