Up to the previous Ubuntu versions you could easily switch on a status line at the bottom of the files browser, which showed useful infos like the amount of free disk space, number of files in directory, number of selected files and amount of data of selected files.
How do I get these informations with Raring Ringtail?
sigh
Imagine you want to copy a 5 GB file to a USB drive or memory stick and the computer just says "not enough free space" - how should you know whether you have to delete just a few MB to make it fit or wheter the device is full? And when you multi-select files to copy or delete, do you then have to calculate by yourself?
Soemtimes I really wonder how others are using their computer when a feature is removed that seems to be totally essential. Maybe they have tons of terabytes of hard disk drives and a couple of 64+ GB flash memory sticks so they never run out of free space.
w-sky
  • 1,354
  • 14
  • 24
You need to switch file browsers or submit a bug to have the feature re-added. The maintainers of that project decided to remove it for some (IMO) nonsense reason that I will likely never be convinced of.
Ranting aside your only options are to find a fork where someone put it back, like nemo, use a different file manager (there are several), or complain a lot in bug reports and mailing lists till the maintainers put it back or allow you to put it back (it is opensource after all).
coteyr
  • 18,724
A tad late, perhaps, but right-clicking in the directory and choosing the "Properties" option at least shows you the amount of free space on the device concerned. Although it is not, in my opinion, a desirable solution, it beats the disk usage analyzer option.
Ruud
This question Diskspace status bar missing after ubuntu 13.04 update talks about a way to solve the problem "Just search in the the dash "disk usage analyzer" with out the quotes and open it up, it will show you how much space is used and how much is left for all of the storage devices plugged into the computer including the hard drive(s)."
I am however running KDE so I am unable to test if this solution works or not. Please let me know if it doesn't.
jjesse
  • 1,115
