10
After installing Ubuntu 13.04 the possibility to install dictionaries to GoldenDict is lost.
I downloaded a big collection for StarDict and usually copied it to the folder: /usr/share/stardict/dic/. Next time after running GoldenDict it included these dictionaries automatically.
After installing 13.04 it doesn't work. I pressed F3, added this folder, selected "Recursive", pressed "Update" (maybe not precise translation from Ukrainian) - and nothing happened.
I tried to copy dictionaries to Home folder and added it - nothing happen.
What's wrong?
Braiam
  • 69,112
v_mil
  • 511
The following command
sudo apt-get install goldendict
sudo apt-get install goldendict-wordnet
will do.
goldendict: dictionary lookup program.
WordNet is a large lexical database of English. Nouns, verbs, adjectives and adverbs that are linked together by their semantic relationships
Gayan Weerakutti
  • 3,830
  • 28
  • 39
Hope it will help you.....
Now to use the copyright free ‘GNU powered’ English dictionary (about 13MB of size … so it contains a lot) called “GCIDE” then use the below procedure to install it.
sudo apt-get install dict-gcide
Now launch goldendict.
Thats it.
Rference.... http://www.hecticgeek.com/2011/12/how-to-setup-dictionary-ubuntu-linux/
androys
  • 31
This is a bug of GoldenDict. Fixed in the latest GoldenDict (apt repository version).
v_mil
  • 511
open Dictionaries tab in edit> Dictionaries. Disable all other dictionaries by dragging and dropping into Inactive dictionaries. click apply and then ok. Close and reopen Goldendict.
Mobee
