I tried to install zRam using the following commands in the terminal:
sudo add-apt-repository ppa:shnatsel/zram
sudo apt-get update
sudo apt-get install zramswap-enabler
But it throws the following error message which says that the package is not available:
E: Couldn't find package zramswap-enabler
I tried to download and install the zramswap-enabler_0.2.1-0~12~oneiric1_all.deb package, but after the second reboot it stops working.
karel
  • 122,292
  • 133
  • 301
  • 332
To install zRAM, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get install zram-config
Once the installation is done go ahead and reboot your machine.
To check whether it works:
cat /proc/swaps
You can download it here.
And to install
sudo dpkg -i zram-config_0.5_all.deb
Or use Gdebi
Mitch
  • 109,787
zramswap-enabler hasn't been released for 13.04 yet. Unless you can make an updated version yourself, you'll have to wait for Shnatsel to release one (this is according to https://launchpad.net/~shnatsel/+archive/zram, which only lists packages up to Quantal).
Wutaz
  • 541
