16
Ubuntu 12.04.2 LTS
What's going on here?
# apt-get install openjdk-7-jdk
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  consolekit cryptsetup-bin dbus-x11 dconf-gsettings-backend dconf-service
  gconf-service gconf-service-backend gconf2 gconf2-common gvfs gvfs-common
  gvfs-daemons gvfs-libs libatasmart4 libavahi-glib1 libbonobo2-0
  libbonobo2-common libcairo-gobject2 libcanberra0 libck-connector0
  libcryptsetup4 libdconf0 libfontenc1 libgconf-2-4 libgconf2-4 libgdu0
  libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libgnome-keyring-common
  libgnome-keyring0 libgnome2-0 libgnome2-bin libgnome2-common libgnomevfs2-0
  libgnomevfs2-common libgtk-3-0 libgtk-3-bin libgtk-3-common libgudev-1.0-0
  libidl-common libidl0 libllvm3.0 libltdl7 liblvm2app2.2 liborbit2
  libpam-ck-connector libpolkit-agent-1-0 libpolkit-backend-1-0 libsgutils2-2
  libtdb1 libvorbisfile3 libx11-xcb1 libxaw7 libxcb-glx0 libxcb-shape0 libxmu6
  libxpm4 libxv1 libxxf86dga1 libxxf86vm1 mtools openjdk-7-jre policykit-1
  policykit-1-gnome sound-theme-freedesktop udisks x11-utils
Is it possible to install the JDK without half of Gnome and X11? And sound themes? This is a headless (and speakerless) server.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Dr.Haribo
  • 263
UPDATED
I personally try to avoid Java because in my opinion it is very clumsy. These instructions are pieced together from various sources, I had to install Java recently and this should work for you.
If your licensing requirements permit, install Oracle Java. Download java from here, you need to chose which one you need based on what you have installed.
JDK x64
wget --no-check-certificate --no-cookies - --header "Cookie: oraclelicense=accept-securebackup-cookie" http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-x64.tar.gz
JDK x32
wget --no-check-certificate --no-cookies - --header "Cookie: oraclelicense=accept-securebackup-cookie" http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-i586.tar.gz
JRE x64
wget --no-check-certificate --no-cookies - --header "Cookie: oraclelicense=accept-securebackup-cookie" http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jre-7u51-linux-x64.tar.gz
JRE x32
wget --no-check-certificate --no-cookies - --header "Cookie: oraclelicense=accept-securebackup-cookie" http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jre-7u51-linux-i586.tar.gz
Note that you need a workaround for wget and oracle to play nice together.
Create a directory where your Java will live:
sudo mkdir -p /usr/lib/jvm
Move the downloaded Java:
sudo mv jdk-7u51-linux-x64.tar.gz /usr/lib/jvm
Extract Java:
sudo tar zxvf jdk-7u51-linux-x64.tar.gz
Tell Ubuntu that Java exists:
sudo update-alternatives --install /usr/bin/javac javac /usr/lib/jvm/jdk1.7.0_51/bin/javac 1
sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jdk1.7.0_51/bin/java 1
sudo update-alternatives --set javac /usr/lib/jvm/jdk1.7.0_51/bin/javac
sudo update-alternatives --set java /usr/lib/jvm/jdk1.7.0_51/bin/java
Add java path to your system profile, so that the machine knows where the Java binaries are:
sudo nano /etc/profile
At the end of the file add this:
JAVA_HOME=/usr/lib/jvm/jdk1.7.0_51
PATH=$PATH:$JAVA_HOME/bin
export JAVA_HOME
export PATH
Save and reboot.
Test your Java installation:
java -version
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Egidijus
  • 106
Very old stuff, but if some one is lookig for this yet, just install openjdk-7-jre-headless or openjdk-6-jre-headless
-1
I think this is not a good idea to skip any dependency when installing from source. You can't skip this all time. When you update dependency using apt-get it will be check there also.
Nabil
  • 2,172
  • 22
  • 29
