39
Possible Duplicate:
How can a script check if it’s being run as root?
This is something I've been curious about. I make a lot of small bash scripts (.sh files) to do tasks that I routinely do. Some of those tasks require everything to be ran as superuser. I've been curious: Is it possible to, within the BASH script prior to everything being run, check if the script is being run as superuser, and if not, print a message saying You must be superuser to use this script, then subsequently terminate the script itself. The other side of that is I'd like to have the script run when the user is superuser, and not generate the error.
Any ideas on coding (if statements, etc.) on how to execute the aforementioned?
Thomas Ward
  • 78,878
