11
I'm having severe issues w/ package-loss and a generally bad connection w/in a WiFi-network at my uni. I'm usually encountering a package loss of ~50% and aborting connections which makes working w/ SaaS impossible.
I'm using Ubuntu 13.04 and my network-adapter is an Atheros AR9462.
Applying the nohwcrypt=1-option doesn't change anything.
Also very noticable: The connection works as intended in other networks; the problematic network uses WPA2 w/ MSCHAPv2.
Anyone can help my out here?
$ sudo lshw -class network  *-network UNCLAIMED
       description: Ethernet controller
       product: NetLink BCM57780 Gigabit Ethernet PCIe
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:04:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:d3500000-d350ffff
  *-network
       description: Wireless interface
       product: AR9462 Wireless Network Adapter
       vendor: Atheros Communications Inc.
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: wlan0
       version: 01
       serial: e0:06:e6:76:ba:89
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
       configuration: broadcast=yes driver=ath9k driverversion=3.8.0-22-generic firmware=N/A ip=131.173.74.130 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
       resources: irq:19 memory:d3400000-d347ffff memory:9fb00000-9fb0ffff
5 Answers5
Looks like a bug in network manager. Bug
Run this command in the terminal:
sudo gedit /etc/NetworkManager/system-connections/essid
Where it says essid in the command above type the name of your wireless network. A file should open then enter your user password change the line "system-ca-certs=true" to "system-ca-certs=false" save and close gedit or whatever text editor you are using, then reboot.
Then connect as you normally do using network manager.
Also some people say just removing "system-ca-certs=true" from the file worked for them but a few people reported that the file recreates itself on reboot that is why I suggest changing true to false instead of removing the line completely.
If you are not using gedit as your text editor in the command above type the name of the editor you are using in place of gedit.
Wild Man
  • 8,327
I have an Acer V5-131 with an AR9462. It worked for some access points but cut out/reconnected on others. This is the line in /etc/modprobe.d/ath9k.conf that fixed it for me:
options ath9k nohwcrypt=1 blink=1 btcoex_enable=1
Good luck.
instead of
Work like a charm for Acer Aspire S3-391
guntbert
  • 13,475
Eric Lan
Could not get my AR9462 wireless working correctly without drops after thirty minutes with the suggestions above on an ASUS X201E that came with 12.04 on any kernel after 3.2.0-54.
Finally stumbled upon this and updated my kernel to 3.12.2-031202-generic and everything works great. If you install this and it doesn't work you can roll back to the previous kernel at boot. How to here: http://www.unixmen.com/linux-kernel-3-12-2-available-download-installation-instructions-ubuntu-linux-mint/
elmus
Changing my router channel to 1 fixed exactly this problem for my AR9462 wireless. None of the ath9k options had any effect.
chrisf
