My root disk is full to the brim because of, I suspect, disk space locked up by a ballooning .xsession-errors file. The ballooning is caused by running processes that keep the error file open and dumping data into it, i.e., PID from several different applications e.g., chromium being the largest culprit. I suspect this is the case because lsof | grep deleted returns lines like:
chromium- 27607 user 2w REG 8,1 1809493864448 108527952 /home/user/.xsession-errors (deleted)
chromium- 27762 user 2w REG 8,1 1809493864448 108527952 /home/user/.xsession-errors (deleted)
The twist here is that I have a cron job set to delete the file home/user/.xsession-errors` as per a suggested work around to this issue. You can imagine how this situation runs a mock quickly when chromium opens up umpteen processes! I am using a 64bit UBUNTU 12.04 machine with the following HD (EXT4) config:
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 1.8T 34G 1.7T 2% /
udev 12G 4.0K 12G 1% /dev
tmpfs 4.8G 1.2M 4.8G 1% /run
none 5.0M 16K 5.0M 1% /run/lock
none 12G 2.1M 12G 1% /run/shm
/dev/sde1 1.8T 450G 1.3T 26% /media/SEA2T
/dev/sdd1 2.7T 201M 2.6T 1% /media/BUFF3T
/dev/sdb 3.6T 118G 3.3T 4% /media/INDAR
/dev/sdc 3.6T 3.0T 469G 87% /media/ALAYA
What I've done so far to resolve in vain:
- Is it possible to reclaim this space? Apparently not in my case, though others have managed to truncate the file to free up the the disk.
- As this seems to be a sort of virtual occurrence, with no real file(s) as culprit, rebooting was the working option for me.
- How To ensure this doesn't happen again? I still don't know. The current workaround is setting the
ERRFILEvariable in the file/etc/X11/Xsessionto/tmp/$USER-xsession-errors
in order to figure out what is being dumped to this error file. I appreciate any suggestions as to how to deal with the run away xsession-errors file once and for all! Thanks in advance.
