I had my Mac set up with rEFIt and installed Ubuntu 13.04, unfortunately GRUB was installed over rEFIt. I was not expecting this and have since found out that I have no idea where my installation disk is for OSX 10.8. I want to boot to OSX, but I cannot do boot repair using any OSX tools since I have lost the ability to boot to this. Any suggestions?
GRUB lists the Ubuntu options along with Mac OSX 32 and 64bit, neither of which work.
iamwpj
  • 231
5 Answers5
Try holding down the Option key while powering on the computer. This should enable you to boot OS X, from which you can re-install rEFIt (or install rEFInd instead, if you care to upgrade, since rEFIt is no longer being maintained).
Rod Smith
  • 45,120
  • 66
  • 108
I actually figured this out. The easiest way in any situation where GRUB overwrites rEFIt is to hit C when the GRUB screen loads. This will bring up the grub command line. Typing exit here will exit GRUB and show you rEFIt. From here a boot into OSX will allow you to uninstall GRUB and install rEFInd.
iamwpj
  • 231
The following did the job for me (based on iamwpj's suggestion):
  • Reboot
  • In the Grub menu, press escape.
  • You get a command line. Type exit.
  • rEFIt/rEFInd will show up. Boot OS X.
  • Tell Startup Disk that you want to boot your OS X install by default.
  • Reboot. Your computer will automatically boot OS X. (Not sure if this step is necessary).
  • Reinstall rEFInd (or, if you insist, rEFIt) the usual way.
  • Next time you boot, you'll get rEFInd.
I solved this for my friend with the same or a similar problem (Refind was over-ridden by Grub without me being consulted after installing Ubuntu).
I had a Mountain Lion USB stick made by dd-ing an ISO to a USB stick.
After pressing the on button I used the alt key on a USB PC keyboard, and a boot screen showed.
I went to the menu to reboot into the Mac mode, this bypasses the grub problem.
Once logged into the original OS X system, I reinstalled Refind by opening the Terminal and dragging the Refind install.sh file into the Terminal, hitting enter and entering the sudo password.
I rebooted and was greeted by Refind again :)
You could probably also use efibootmgr or another EFI tool from Ubuntu to tell the UEFI to load rEFIt/rEFInd first. There is some documentation on the rEFInd pages about removing Grub to prevent re-occurrences of this issue (which I've run into myself).
dragon788
  • 1,716
