10
In the qml documentation there is a drag'n'drop example:
import QtQuick 2.0
Item {
    width: 200; height: 200
    DropArea {
        x: 75; y: 75
        width: 50; height: 50
        onDropped: console.log("dropped")
        onEntered: console.log("entered")
        Rectangle {
            anchors.fill: parent
            color: "green"
            visible: parent.containsDrag
    Rectangle {
        x: 10; y: 10
        width: 20; height: 20
        color: "red"
        Drag.active: dragArea.drag.active
        Drag.hotSpot.x: 10
        Drag.hotSpot.y: 10
        MouseArea {
            drag.target: parent
I have added the two lines with "onDropped" and "onEntered". While "onEntered" is triggered by dragging the small rectangle, I can not make the "onDropped" to trigger.
What do I have to do to make it trigger?
xubuntix
  • 5,580
Apparently a drop needs to be generated explicitly by calling the drop() method on the Drag object
Try adding this line inside of the MouseArea, just above drag.target: parent
onReleased: parent.Drag.drop()
