I am trying to install the AMD Catalyst version 13.1 driver on Ubuntu 12.04 LTS (desktop version).
I have downloaded the *.run file corresponding to the driver version.
amd-driver-installer-catalyst-13.1-linux-x86.x86_64.run
I am following the instructions to install Catalyst here:
https://askubuntu.com/a/126513
All the dependencies were downloaded as well.
When I run:
It fails to build the package with the error:
Generating package: Ubuntu/precise
Package build failed!
Package build utility output:
./packages/Ubuntu/ati-packager.sh: 294: ./packages/Ubuntu/ati-packager.sh: debclean: not found
make: *** [binary-arch] Error 2
dpkg-buildpackage: error: debian/rules binary gave error exit status 2
I downloaded devscripts as well to fix the error related to debclean.
sudo apt-get install devscripts
Reading package lists... Done
Building dependency tree
devscripts is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 189 not upgraded.
As you can see, I have the latest version of debclean installed. Even after this, it fails to build the package when I run with the same error specific to "debclean not found". How can I fix this error?
sudo sh amd-driver-installer-catalyst-13.1-linux-x86.x86_64.run --buildpkg Ubuntu/precise
Thanks.
Just try this link. It may help. At least it will guide you how to cover the problem.
Regards.
P.S.: I have ATI Mobility Radeon HD 4xxx series and it worked for my cause.
