31
I want to copy a file to all subfolders in a folder. How can I do this with the command line?
Tim
  • 33,500
How to put a file in the current working directory in all subfolders (and maybe their subfolders, depending on what you want to do)
This will put the file in all of the subfolders, but not their subfolders:
for d in */; do cp water.txt "$d"; done
This will put the file water.txt (change all instances of water.txt to the filename you want to copy) in all the subfolders and their subfolders
for i in ./* # iterate over all files in current dir
do
    if [ -d "$i" ] # if it's a directory
    then
        cp water.txt "$i" # copy water.txt into it
    fi
done
Info from this linuxquestions thread
20
You could use that one-liner:
find <target-dir> -type d -exec cp <the file> {} \;
limit depth to 1 -> only the immediate directories
find <target-dir> -type d -maxdepth 1 -exec cp <the file> {} \;
ortang
  • 2,183
  • 14
  • 13
