I have a dual graphics card: intel 4000 and nvidia 630m...
I installed bumblebee and intel drivers from their website. I thought the brightness problem will be solved by installing these drivers.
But, brightness works only for two steps: that is, dim, medium, high... But, it doesn't increase step wise. Can you please help me sort this problem?
I'm a newbie to ubuntu and this is my first trial. So, please give me a detailed guide... Thank you :)
EDIT: My model is HP DV6 7040tx. My Laptop Model
I finally figured out in this thread: How to control Brightness
Just to keep it straight
Run the following command in Terminal:
sudo gedit /etc/default/grub
then change
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
GRUB_CMDLINE_LINUX="acpi_osi=Linux"
then save and run:
sudo update-grub
and then restart the system for changes to take effect.
Go to system settings --> Brightness & Lock. Here you can manually set your brightness by sliding the bar to the left/right. Hope this helps!
Cedric
  • 39
Ok, I found it.
I changed acpi_osi=Linux to acpi_osi=Linux backlight=vendor, then ran:
sudo update-grub2
A reboot and the sensitivity is fixed.
It seems all Intel/Nvidia dual graphics card are affected by this.
Look for nvidia panel in dash, open it up and make the changes there.
Arup Roy Chowdhury
  • 1,580
