20
it was so easy to show the weather in the panel, without installing an app.
why won't that be possible anymore in 11.04?
Braiam
  • 69,112
melodram
  • 711
The weather feature of the time/date applet was removed (weather isn't related to time :), and the weather indicator is now a separate application: indicator-weather Install indicator-weather
After you've installed it you can run it from the dash or add it to your startup applications.
You could install this in Natty if you need it, or even file a bug report asking them to include it by default. If you do, you can add that link to your question (for the bug) so others who are interested can say it affects them.
RolandiXor
  • 51,797
The weather-applet used in pre-11.04 requires the use of 'gnome-panel'. By default Ubuntu 11.04 uses the Unity desktop interface which does not use 'gnome-panel'.
A weather-indicator can be installed from the Ubuntu Software Centre. This has much (if not all) of the functionality the weather-applet provided.
If you don't mind adding a PPA to your software sources list, I'd recommend Lorenzo Carbonell's my-weather indicator. Instructions to install the package:
sudo add-apt-repository ppa:atareao/atareao
sudo apt-get update && sudo apt-get install my-weather-indicato
Actually, if you do mind adding another PPA, you can just go ahead and get the .deb file from http://ppa.launchpad.net/atareao/atareao/ubuntu/pool/main/m/my-weather-indicator/.
Source: http://www.omgubuntu.co.uk/2014/10/install-weather-indicator-ubuntu-14-10
As of 9-23-16, the "weather-app in the panel" is once again able to show the temperature of your chosen locations once you have OK'd the (automatic) software update. Thank you!!! I was surprised how much I missed it.
