I am trying to install the meld diff viewer on Ubuntu 12.04 LTS. When I run
sudo apt-get install meld
I get the following output:
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  libgtksourceview2.0-0 libgtksourceview2.0-common python-glade2 python-gnome2 python-gtksourceview2
  python-pyorbit
Suggested packages:
  python-gtk2-doc python-gnome2-doc libgtksourceview2.0-dev python-pyorbit-dbg
The following NEW packages will be installed:
  libgtksourceview2.0-0 libgtksourceview2.0-common meld python-glade2 python-gnome2
  python-gtksourceview2 python-pyorbit
0 upgraded, 7 newly installed, 0 to remove and 57 not upgraded.
Need to get 0 B/1,048 kB of archives.
After this operation, 5,255 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Selecting previously unselected package libgtksourceview2.0-common.
(Reading database ... 60%dpkg: unrecoverable fatal error, aborting:
reading files list for package 'python-aptdaemon.gtk3widgets': Input/output error
E: Sub-process /usr/bin/dpkg returned an error code (2)
Is there something wrong with the package libgtksourceview2.0-common? Is there a way to get a better update, or another way to get meld installed? I am uncertain how to proceed...
Alvar
  • 17,038
txmystic
  • 333
I just tried installing Meld on my 12.04 installation, using sudo apt-get install meld, and it worked with no problems.
Try this. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get update && sudo apt-get upgrade
If that dosen't work, try installing the latest python
sudo apt-get install python3
Mitch
  • 109,787
There is nothing wrong with the package, the install on my 12.04 system worked just fine. Try to update your dateabase first, then do the install:
sudo apt-get update
ubfan1
  • 19,049
Just use sudo aptitude install meld.
If you are not familiar with aptitude, check this post: Aptitude vs. apt-get: Which is the recommended (aka the “right”) tool to use?
aptitude and apt-get work the same for many tasks, but for the most tricky cases, such as distribution upgrades (apt-get dist-upgrade vs. aptitude full-upgrade), they have different rules, and aptitude's rules are nearly always better in practice where they disagree.
If you don't have installed aptitude, use apt-get:
sudo apt-get update
sudo apt-get install aptitude
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
