I had installed Gnome Activity Journal, Zeitgeist and Tracker but borked the install by mixing the PPAs with the universe repos. I removed all the packages, did apt-get remove --purge, then did a locate to manually rm everything else.
Then I reinstalled from the PPAs properly. Now I can't tag files anymore, either in Nautilus or GAJ. What packages are involved in tagging? What else might I be missing?
Isaiah
  • 60,750
GAJ maintainer here. Since the last version (0.6) the tagging feature (powered by Tracker) has been removed from GAJ, due to problems and random crashes. For what concerns Nautilus, as far i know, installing Tracker should let you tag out of the box.
