After an installation of MySQL, I get a few errors and I can't run the MySQL daemon. I've tried uninstalling and reinstalling several times, and I'm not sure what's going on.
Here's a snippit of what I'm seeing:
Setting up mysql-server-5.5 (5.5.31-0ubuntu0.13.04.1) ...
runlevel:/var/run/utmp: No such file or directory
initctl: Unknown job: mysql
sudo service mysql start gives me an unknown job error, and mysqld isn't found on my system.
I'm not sure where to go from here, aside from maybe compiling from source and creating my own upstart script. Of course, I'd like to do things the easy way if possible.
How can I successfully run MySQL or fix this problem?
Here is the complete log of what happens when I run the installation command:
sudo apt-get install mysql-server
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  libaio1 libdbd-mysql-perl libdbi-perl libnet-daemon-perl libplrpc-perl libterm-readkey-perl mysql-client-5.5 mysql-client-core-5.5
  mysql-server-5.5 mysql-server-core-5.5
Suggested packages:
  tinyca mailx
The following NEW packages will be installed:
  libaio1 libdbd-mysql-perl libdbi-perl libnet-daemon-perl libplrpc-perl libterm-readkey-perl mysql-client-5.5 mysql-client-core-5.5 mysql-server
0 upgraded, 11 newly installed, 0 to remove and 13 not upgraded.
Need to get 0 B/25.4 MB of archives.
After this operation, 88.0 MB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Preconfiguring packages ...
Selecting previously unselected package libaio1:i386.
(Reading database ... 159063 files and directories currently installed.)
Unpacking libaio1:i386 (from .../libaio1_0.3.109-3_i386.deb) ...
Selecting previously unselected package libnet-daemon-perl.
Unpacking libnet-daemon-perl (from .../libnet-daemon-perl_0.48-1_all.deb) ...
Selecting previously unselected package libplrpc-perl.
Unpacking libplrpc-perl (from .../libplrpc-perl_0.2020-2_all.deb) ...
Selecting previously unselected package libdbi-perl.
Unpacking libdbi-perl (from .../libdbi-perl_1.622-1_i386.deb) ...
Selecting previously unselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from .../libdbd-mysql-perl_4.021-1_i386.deb) ...
Selecting previously unselected package mysql-client-core-5.5.
Unpacking mysql-client-core-5.5 (from .../mysql-client-core-5.5_5.5.31-0ubuntu0.13.04.1_i386.deb) ...
Selecting previously unselected package libterm-readkey-perl.
Unpacking libterm-readkey-perl (from .../libterm-readkey-perl_2.30-4build4_i386.deb) ...
Selecting previously unselected package mysql-client-5.5.
Unpacking mysql-client-5.5 (from .../mysql-client-5.5_5.5.31-0ubuntu0.13.04.1_i386.deb) ...
Selecting previously unselected package mysql-server-core-5.5.
Unpacking mysql-server-core-5.5 (from .../mysql-server-core-5.5_5.5.31-0ubuntu0.13.04.1_i386.deb) ...
Selecting previously unselected package mysql-server-5.5.
Unpacking mysql-server-5.5 (from .../mysql-server-5.5_5.5.31-0ubuntu0.13.04.1_i386.deb) ...
Selecting previously unselected package mysql-server.
Unpacking mysql-server (from .../mysql-server_5.5.31-0ubuntu0.13.04.1_all.deb) ...
Processing triggers for man-db ...
Processing triggers for ureadahead ...
Setting up libaio1:i386 (0.3.109-3) ...
Setting up libnet-daemon-perl (0.48-1) ...
Setting up libplrpc-perl (0.2020-2) ...
Setting up libdbi-perl (1.622-1) ...
Setting up libdbd-mysql-perl (4.021-1) ...
Setting up mysql-client-core-5.5 (5.5.31-0ubuntu0.13.04.1) ...
Setting up libterm-readkey-perl (2.30-4build4) ...
Setting up mysql-client-5.5 (5.5.31-0ubuntu0.13.04.1) ...
Setting up mysql-server-core-5.5 (5.5.31-0ubuntu0.13.04.1) ...
Setting up mysql-server (5.5.31-0ubuntu0.13.04.1) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Here are the contents of /var/log/mysql/error.log immediately after the apt-get command is run to install it.
130518 12:14:36 [Note] Plugin 'FEDERATED' is disabled.
130518 12:14:36 InnoDB: The InnoDB memory heap is disabled
130518 12:14:36 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130518 12:14:36 InnoDB: Compressed tables use zlib 1.2.7
130518 12:14:36 InnoDB: Using Linux native AIO
130518 12:14:36 InnoDB: Initializing buffer pool, size = 128.0M
130518 12:14:36 InnoDB: Completed initialization of buffer pool
130518 12:14:36 InnoDB: highest supported file format is Barracuda.
130518 12:14:36  InnoDB: Waiting for the background threads to start
130518 12:14:37 InnoDB: 5.5.31 started; log sequence number 1595675
130518 12:14:37  InnoDB: Starting shutdown...
130518 12:14:38  InnoDB: Shutdown completed; log sequence number 1595675
130518 12:14:38 [Note] Plugin 'FEDERATED' is disabled.
130518 12:14:38 InnoDB: The InnoDB memory heap is disabled
130518 12:14:38 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130518 12:14:38 InnoDB: Compressed tables use zlib 1.2.7
130518 12:14:38 InnoDB: Using Linux native AIO
130518 12:14:38 InnoDB: Initializing buffer pool, size = 128.0M
130518 12:14:38 InnoDB: Completed initialization of buffer pool
130518 12:14:38 InnoDB: highest supported file format is Barracuda.
130518 12:14:38  InnoDB: Waiting for the background threads to start
130518 12:14:39 InnoDB: 5.5.31 started; log sequence number 1595675
ERROR: 1064  You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AL
TER TABLE user ADD column Show_view_priv enum('N','Y') CHARACTER SET utf8 NOT ' at line 1
130518 12:14:39 [ERROR] Aborting
130518 12:14:39  InnoDB: Starting shutdown...
130518 12:14:40  InnoDB: Shutdown completed; log sequence number 1595675
130518 12:14:40 [Note] /usr/sbin/mysqld: Shutdown complete
6 Answers6
Looks like many applications rely on /var/run/utmp for logon session information.
sudo touch /var/run/utmp
sudo chmod 664 /var/run/utmp
sudo reboot
after the reboot, execute these commands, as @coteyr suggested, to clean install mysql
sudo apt-get purge mysql-server
sudo apt-get update
This should resolve your problem.
EDIT:
sudo apt-get purge mysql-common
sudo rm -rf /var/log/mysql
sudo rm -rf /var/log/mysql.*
sudo rm -rf /var/lib/mysql
sudo rm -rf /etc/mysql
sudo apt-get install mysql-server --fix-missing --fix-broken
This seems to be working for so many people, as per this blog post
thefourtheye
  • 4,922
  • 26
  • 32
The problem is not directly related to MySql. The init daemon control tool is not starting the mysql server daemon into /etc/init.
You can restore by hand:
sudo initctl reload-configuration
Now mysql server starts as expected.
Temo
  • 61
about the unknown job, mine solved using this
sudo /etc/init.d/mysql start
instead of this
Here where I refer
Ariff
  • 41
Then once it's installed make sure /var/lib/mysql exists and that /etc/init.d/mysql exists. /usr/bin/mysqld and /usr/bin/mysqld_safe should also exist.
If your still having problems then there's a problem with package (assuming you get no errors there). You can "purge" it, "update" and then "install" the package to see if that clears the error.
sudo apt-get update
If that still doesn't work you will need to file a bug with the package maintainers.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
coteyr
  • 18,724
This is probably not a tech solution but more a work around. I've tried this and everything else that's making rounds on the internet to fix this problem. Nothing worked. At last I downgraded the packages back to MYSQL 5.29 and it worked like a charm. Thanks.
I just had this problem now and solved it.
Although you installed mysql-server, the daemon needs to be running in order for the client to connect to it.
First check to see if mysql server is running:
netstat -tap | grep mysql
You should see something like this:
$ sudo netstat -tap | grep mysql
tcp        0      0 localhost:mysql         *:*          LISTEN     6639/mysqld
If you don't have the server running, start the daemon by the following command:
/etc/init.d/mysql restart
This should solve your problem.
