I have set my crontab to run 2 script:
$ crontab -l
0 20 * * * /usr/bin/bkp.sh --silent > /home/perforce/logs/bkp.log 2>&1
0 21 * * * /usr/bin/flsbk.sh --silent > /home/perforce/logs/flsbk.log 2>&1
The first script is not running.
I set up on crontab -e not sudo crontab -e
The error I have is this. From /home/perforce/output.log:
Starting Backup
Output location:  /home/perforce/output.log
Running p4 verify...
/usr/bin/bkp.sh: line 22: p4: command not found
Done! (No error)
Running p4 admin checkpoint...
/usr/bin/bkp.sh: line 46: p4: command not found
Done!
/usr/bin/bkp.sh: line 51: p4: command not found
 (Error)
And my script is this:
#!/bin/bash
echo
echo "===================================================================================="
echo "Starting Backup"
# Defines output folder and log name
OUTPUT_FOLDER='/home/perforce/'
OUTPUT_FILE='output.log'
OUTPUT=$OUTPUT_FOLDER$OUTPUT_FILE
echo "Output location: " $OUTPUT
# Creates a temp file
TMPFILE=`mktemp`
echo -n "Running p4 verify..."
# Run the p4 and send the output to the temp file
p4 verify -q //... > $TMPFILE
echo -n " Done!"
# Check if it's empty (no error)
# Copy the content to another variable, so we don't mess up with the original output
RESULT=`cat $TMPFILE`
if [ "$RESULT" != "" ];
then
  echo " (Error, saving to log)"
  # Save error on output file
  `echo $RESULT > $OUTPUT`
  exit
fi
echo " (No error)"
echo -n "Running p4 admin checkpoint..."
p4 admin checkpoint > $TMPFILE
echo -n "Done!"
# The file created by the last command
COUNTER=`p4 counter journal`
FILE=/perforce_depot/checkpoint.$COUNTER
# Check if the file was created
if [ -f "$FILE" ]
then
  echo " (No error)"
else
  echo " (Error)"
  exit
fi
echo  -n "Backing up ..."
# Finaly, let's create the backup
#`cp -r /perforce_depot  '/media/perforce/Seagate Backup Plus Drive/perforcebk'`
START=$(date +%D)
FOLDER_NAME=`echo $START | tr -s '/' | tr '/' '_'`
FOLDER_PATH='/media/perforce/BackupDrive/perforcebk'
BACKUP_PATH=$FOLDER_PATH/bkp_$FOLDER_NAME
mkdir -p $BACKUP_PATH
cp -r /perforce_depot $BACKUP_PATH
echo " Done!"
p4 is located into /usr/local/bin
Any one have any idea why i am getting that error? If I ssh to the machine and run manually sh bhp.sh it runs without a problem and any errors.
Cron scripts do not run in your 'normal' environment. The output clearly states:
This can mean just that $PATH does not include /usr/local/bin, that's all. So modify your cron script and add this after your shebang:
#!/bin/bash
set -e
PATH="/usr/local/bin:$PATH"
Note: set -e will make your script quit if some commands fail. It is not required to solve your specific problem, but it may solve a lot of headaches in the future. Consider using it in all your scripts.
