sudo add-apt-repository ppa:ferramroberto/java
After this command I am getting error:
Error reading https://launchpad.net/api/1.0/~ferramroberto/+archive/java: Couldn't resolve host 'launchpad.net
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Bhagya
  1. To add our PPA and install the latest Oracle Java (JDK) 7 in Ubuntu, use the commands below:
    sudo add-apt-repository ppa:webupd8team/java
    sudo apt-get update && sudo apt-get install oracle-jdk7-installer
  2. After the installation you have enable the jdk:
    update-alternatives –display java
  3. Check if Ubuntu uses Java JDK 7
    java -version
    The correct answer should be like this:
    javac 1.7.0_07
  4. Adding JAVA_HOME to environment
    Edit the file /etc/environment and add JAVA_HOME=/usr/lib/jvm/java-7-oracle to the end of the file.
    First open a Terminal (Applications → Accessories → Terminal), then enter:
    sudo gedit /etc/environment
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
