24
I want to get a program (a script that can be set to auto-start or something) that tells you every hour like "It's 11 o'clock."
I know it's easy on Macs, but how do you get that on Precise?
Jorge Castro
  • 73,717
There's a program in the standard repos for it, saytime.
sudo apt-get install saytime
Then you can run saytime -r 3600 to run it every hour (3600 seconds, or change the number for a different interval in seconds). It will start as a background process when run with this option.
If you want to change the format (for example to remove the "and X seconds") it would be saytime -r 3600 -f %P%l%M - full format options in man saytime.
Source: http://ubuntuforums.org/showthread.php?t=516600&p=3130400#post3130400
Jez W
  • 2,108
sudo apt-get install festival
If you wanna get crazy you can also add to gnome-schedule:
echo This is my custom message | festival --tts
Where custom message can include the output of the command
date
and if you want a nicer voice try something like:
sudo apt-get install festvox-us1
echo "(set! voice_default 'voice_us1_mbrola)" | sudo tee -a /etc/festival.scm
Jonathan
  • 3,984
The current espeak version (1.48.3) links directly to mbrola voices. So you can obtain a good result with something like:
date|espeak -v en-us
Parms are available to espeak to tweak the voice. See it's man for more options.
