Quite a while back i'd worked briefly on Red Hat, and it had this option of booting into root directly, and not using the su command to change your access. I know that by default the root account is disabled in Ubuntu and for all practical purposes is as good as non existent, but still suppose it is unlocked, can we log into root directly?
Ideas?
Projjol
  • 1,120
The root account is not disabled, it is locked.
The preferred method is to use sudo, specifically sudo -i
See: https://help.ubuntu.com/community/RootSudo
You can run graphical applications with gksu, it needs to be installed on 13.04
sudo apt-get install gksu
You can always boot to a root shell by booting to recovery mode and dropping to a root shell.
You can ssh in as root using keys or by setting a password.
Panther
  • 104,528
