57
I am trying to change root password in my Ubuntu system.
This is what I did:
ashot@ashot-desktop:~$ sudo passwd root
passwd: Authentication token manipulation error
passwd: password unchanged
How do I change root password in Ubuntu?
Ashot
  • 671
5 Answers5
72
Usually there is no need to set a root password. See: https://help.ubuntu.com/community/RootSudo
To set or change your (root) password:
sudo -i
passwd
To lock it again
sudo passwd -dl root
Panther
  • 104,528
16
When you use sudo your already accessing root you don't have to specify root.
sudo passwd
If your trying to do this from recovery root you should:
mount -rw -o remount /
passwd
heemayl
  • 93,925
Nade
  • 331
If 'ashot' is your root account, don't call 'sudo passwd'. I've been doing that for the past few months and it wouldn't change my password.
To change my password, I had to call 'passwd' without 'sudo'. Otherwise, the password modification is not taken account of.
I installed a .deb file which created for pardus, when i install this package to ubuntu, my ubuntu is gone, i had never been super user also couldn't use passwd to change password.
I got the same error :
Try this steps;
- restart ubuntu, open it recovery mode
- drop root
- upgrade your ubuntu to a new version
This solved my problem, i hope it helps you too.
Possibly /etc/passwd and /etc/shadow don't match.
Try to use command pwconv.
heemayl
  • 93,925
Pavel
  • 1,556
