When trying to start ICEMCFD (a meshing tool for flow simulations) I receive an error message and analysing it with LIBGL_DEBUG=verbose yields:
ldzq68@DS-ECSTL-001:/usr/ansys_inc/v121/icemcfd/linux/bin$ LIBGL_DEBUG=verbose ./icemcfd
ICEM_ACN is /usr/ansys_inc/v121/icemcfd/linux
ANSYSLIC_DIR is set to /usr/ansys_inc/shared_files/licensing
args
Window information: depth = 24
                    class = 4
visual depth = 24 class = 4
libGL: OpenDriver: trying /usr/lib/i386-linux-gnu/dri/tls/r600_dri.so
libGL: OpenDriver: trying /usr/lib/i386-linux-gnu/dri/r600_dri.so
libGL error: dlopen /usr/lib/i386-linux-gnu/dri/r600_dri.so failed (/usr/ansys_inc/v121/icemcfd/linux/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /usr/lib/i386-linux-gnu/libLLVM-3.1.so.1))
libGL: OpenDriver: trying ${ORIGIN}/dri/tls/r600_dri.so
libGL: OpenDriver: trying ${ORIGIN}/dri/r600_dri.so
libGL error: dlopen ${ORIGIN}/dri/r600_dri.so failed (${ORIGIN}/dri/r600_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib/dri/tls/r600_dri.so
libGL: OpenDriver: trying /usr/lib/dri/r600_dri.so
libGL error: dlopen /usr/lib/dri/r600_dri.so failed (/usr/lib/dri/r600_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL: OpenDriver: trying /usr/lib/i386-linux-gnu/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/i386-linux-gnu/dri/swrast_dri.so
libGL error: dlopen /usr/lib/i386-linux-gnu/dri/swrast_dri.so failed (/usr/ansys_inc/v121/icemcfd/linux/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /usr/lib/i386-linux-gnu/libLLVM-3.1.so.1))
libGL: OpenDriver: trying ${ORIGIN}/dri/tls/swrast_dri.so
libGL: OpenDriver: trying ${ORIGIN}/dri/swrast_dri.so
libGL error: dlopen ${ORIGIN}/dri/swrast_dri.so failed (${ORIGIN}/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/dri/swrast_dri.so
libGL error: dlopen /usr/lib/dri/swrast_dri.so failed (/usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
X Error of failed request:  BadAlloc (insufficient resources for operation)
  Major opcode of failed request:  154 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Serial number of failed request:  5496
  Current serial number in output stream:  5500
After reading other threads I tried updating libstdc++6 and
sudo apt-get install libstdc++6
tells me libstdc++6 is already the newest version.
So following this advice I updated my stdc++ libraries using
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
but I still receive the same error when I want to start ICEM.
Zanna
  • 72,312
Solved it by installing the xfonts-75dpi and xfonts-100dpi libraries after finding this.
