10
I was trying to edit GRUB file at /etc/default/ for fixing the brightness issue.
But I am unable to do that as there is no option to save GRUB file after edit. This may be due to some permission issue.
How should I edit this file?
And issue I am trying to fix is: "display brightness problem with ubuntu 13.04"
You need to open the file as root.
gksu gedit /etc/default/grub
On 13.04 or later you might have to first install gksu:
sudo apt-get install gksudo
See also https://help.ubuntu.com/community/RootSudo
kiri
  • 28,986
Panther
  • 104,528
