When I want to add a folder to PLEX I cannot find it.
I have 2 harddrives in my computer. Ubuntu 13 installed on the 120GB SSD and another 1TB normal harddrive which contains 1 Folder called 'Films'. In that folder there are many other folders with films in it.
When I add a Movie section from PLEX I can select the 1TB harddrive. So the drive is recognized. But afterwards I cannot select the folder 'Films' althoug it is there.
The filemanager (second icon from the top on menu bar) does show the folder.
Any clue how I can make sure PLEX recognizes this folder so I can select it?
Here is my solution:
Remove the old installation of plex:
sudo apt-get remove plexmediaserver
sudo apt-get purge plexmediaserver
sudo rm -r plexmediaserver/
Download plex from the website
Go to Downloads folder
Install plex:
sudo dpkg -i plexmediaserver_0.9.7.22.511-4b5280f_amd64.deb
change user to you instead of plex:
sudo nano /etc/default/plexmediaserver
Run once
http:// localhost:32400/web/index.html#!/dashboard
Stop:
sudo service plexmediaserver stop
add user to group:
sudo addgroup plex youruser
sudo addgroup youruser plex
start:
sudo service plexmediaserver start
Seth
  • 59,332
anonynous
  • 221
This because plex does not support sub folders. What id did was copy all my movies out of their sub folders and into a new folder. Try executing the following commands
mkdir ~/PlexMovies
find ~/Videos -name '*.mp4' -exec cp {} ~/PlexMovies \;
Now this assumes that all your videos are in the mp4 format. Execute this command for every type of video you have by replacing *.mp4 with any other movie type. Then have plex pull your movies from ~/PlexMovies
chad
  • 965
