I want to create a new user to run a service on the system but don't want to have /home and other configuration files for it. Like there is a user for postgres but it doesn't have any /home directory.
- 36,890
- 56
- 97
- 151
- 7,523
By default the command useradd doesn't create home directories, but for a daemon I recommend you to use the system option and change the shell to a non-existent one so no one can login with said account (in ssh for example):
sudo useradd -r -s /bin/false USERNAME
You can see all the options with man useradd and man groupadd if you want to create a group for the user too.
- 149
- 2,962
Try adduser --system --no-create-home USERNAME or simply have a look at the man adduser which claims to be a "friendlier front end to the low level tools like useradd...".
- 119,640
- 5,057
I needed something similar - a new user without login privileges and tied to a system service. However, the answer by Clausi creates a user with the primary group as 'nogroup', which wasn't really desirable.
adduser --system --no-create-home --group USERNAME creates a system group with the same name as the user and associates it with the user as the primary group. This can then be verified by using the groups USERNAME or the id USERNAME command.
- 231
- 2
- 2
To add user without home directory the commands are,
useradd -M username
or
useradd --no-create-home username
or
adduser -M username
or
adduser --no-create-home username
- 13,582
- 81
Creating a User without Password with Home directory:
User & Group
Create the desired Group and User with Home-Dir.
mkdir <HOME-DIR>
sudo adduser --disabled-password --home <HOME-DIR> --group <GROUP-NAME>
sudo useradd -s /bin/bash -d <HOME-DIR> -g <GROUP-NAME> <USER-NAME>
Permissions
sudo chown <USER>:<USER> -R <HOME-DIR> # Owner permissions
sudo chmod 775 -R <HOME-PATH> # Optional
Add your primary user to the new group (Optional)
sudo usermod -a -G <GROUP-NAME> <PRIMARY-USER-NAME>
To see all the groups, use: $ id, $ groups. login to a user: $ sudo su - <USER>. Re-login or Reset-PC is required.
Remove User and Group
sudo deluser --remove-home <USER-NAME>
- 5,100
