I use nautilus as my default file manager. Is there any way that I can customize it so that right click anywhere in the window gives an option to open the current directory in terminal. I have seen same feature in dolphin, wish I could do the same in nautilus too.
Asked
Active
Viewed 5.7k times
44
Install nautilus-open-terminal. In a terminal type:
sudo apt-get install nautilus-open-terminal
Once it installs, type nautilus -q && nautilus & to quit and reopen nautilus, and check the right click option.
Alaa Ali
- 32,213
I did the following:
nautilus -q
Then just click the file manager window, and then try right clicking anywhere and the option "Open in Terminal" is right there!
Sam-Graham
- 213
To open a terminal from Nautilus, you must install the package nautilus-open-terminal (sudo apt-get install nautilus-open-terminal from the command line). In the context menu is the option to open a terminal in the current directory.
jsartti
- 398
