-1
I know there's a few relevant questions answered but when I try to format it through disk utility the only answer I get is:
"Error synchrinizing after initial wipe: Timed out waiting for object (udisks-error-quark,0)
I'm new to Linux, had no problem with Debian, Ubuntu seemed even friendlier in the start but seems I can't do a simple thing like formatting a usb stick. I know that some of you will tell me to download Gparted or something but since Ubuntu by default has a disk utility that does the job it should work, shouldn't it?
Is something wrong with my dash? Is it something fixable or something missing? When a utility is already there it should work or at least know why it doesn't. Installing and using something else is not a good solution. Formatting is so simple and easy on Debian...
Warren Hill
  • 22,412
  • 28
  • 70
  • 88
This has been reported as a bug, you can check it out here - https://bugs.launchpad.net/ubuntu/+source/udisks/+bug/1059872
you can mention that this bug affects you (at the aforementioned site, i.e.), it'll help give the bug greater attention.
you can always use gparted for formatting a disk. to get gparted, you can use the software centre or enter the following command in the terminal
sudo apt-get install gparted
choose your device, unmount it and then right-click to open a menu. within the menu you'll find a 'format to' option, use that to format it to whichever file format you wish to use, and click on apply.
That should work out perfectly.
Projjol
  • 1,120
