From how to install boost lib, I followed the solution but I was met with the following message:
To add more information, I was trying to install the libs due to this thread I posted: python keplerian toolbox
libboost-all-dev : Depends: libboost-dev but it is not going to be installed
Depends: libboost-chrono-dev but it is not going to be installed
Depends: libboost-date-time-dev but it is not going to be installed
Depends: libboost-filesystem-dev but it is not going to be installed
Depends: libboost-graph-dev but it is not going to be installed
Depends: libboost-graph-parallel-dev but it is not going to be installed
Depends: libboost-iostreams-dev but it is not going to be installed
Depends: libboost-locale-dev but it is not going to be installed
Depends: libboost-math-dev but it is not going to be installed
Depends: libboost-mpi-dev but it is not going to be installed
Depends: libboost-mpi-python-dev but it is not going to be installed
Depends: libboost-program-options-dev but it is not going to be installed
Depends: libboost-python-dev but it is not going to be installed
Depends: libboost-random-dev but it is not going to be installed
Depends: libboost-regex-dev but it is not going to be installed
Depends: libboost-serialization-dev but it is not going to be installed
Depends: libboost-signals-dev but it is not going to be installed
Depends: libboost-system-dev but it is not going to be installed
Depends: libboost-test-dev but it is not going to be installed
Depends: libboost-thread-dev but it is not going to be installed
Depends: libboost-timer-dev but it is not going to be installed
Depends: libboost-wave-dev but it is not going to be installed
How do I fix this?
ii libboost-atomic1.53-dev 1.53.0-3 amd64 atomic data types, operations, and memory ordering constraints
ii libboost-atomic1.53.0 1.53.0-3 amd64 atomic data types, operations, and memory ordering constraints
ii libboost-chrono1.53-dev 1.53.0-3 amd64 C++ representation of time duration, time point, and clocks
ii libboost-chrono1.53.0 1.53.0-3 amd64 C++ representation of time duration, time point, and clocks
ii libboost-context1.53-dev 1.53.0-3 amd64 provides a sort of cooperative multitasking on a single thread
ii libboost-context1.53.0 1.53.0-3 amd64 provides a sort of cooperative multitasking on a single thread
ii libboost-date-time1.49.0 1.49.0-3.2ubuntu1 amd64 set of date-time libraries based on generic programming concepts
ii libboost-date-time1.53-dev 1.53.0-3 amd64 set of date-time libraries based on generic programming concepts
ii libboost-date-time1.53.0 1.53.0-3 amd64 set of date-time libraries based on generic programming concepts
ii libboost-exception1.53-dev 1.53.0-3 amd64 set of date-time libraries based on generic programming concepts
ii libboost-filesystem1.53-dev 1.53.0-3 amd64 filesystem operations (portable paths, iteration over directories, etc) in C++
ii libboost-filesystem1.53.0 1.53.0-3 amd64 filesystem operations (portable paths, iteration over directories, etc) in C++
ii libboost-graph-parallel1.53-dev 1.53.0-3 amd64 generic graph components and algorithms in C++
ii libboost-graph-parallel1.53.0 1.53.0-3 amd64 generic graph components and algorithms in C++
ii libboost-graph1.53-dev 1.53.0-3 amd64 generic graph components and algorithms in C++
ii libboost-graph1.53.0 1.53.0-3 amd64 generic graph components and algorithms in C++
ii libboost-iostreams1.49.0 1.49.0-3.2ubuntu1 amd64 Boost.Iostreams Library
ii libboost-iostreams1.53-dev 1.53.0-3 amd64 Boost.Iostreams Library development files
ii libboost-iostreams1.53.0 1.53.0-3 amd64 Boost.Iostreams Library
ii libboost-locale1.53-dev 1.53.0-3 amd64 C++ facilities for localization
ii libboost-locale1.53.0 1.53.0-3 amd64 C++ facilities for localization
ii libboost-math1.53-dev 1.53.0-3 amd64 Boost.Math Library development files
ii libboost-math1.53.0 1.53.0-3 amd64 Boost.Math Library
ii libboost-mpi-python1.53-dev 1.53.0-3 amd64 C++ interface to the Message Passing Interface (MPI), Python Bindings
ii libboost-mpi-python1.53.0 1.53.0-3 amd64 C++ interface to the Message Passing Interface (MPI), Python Bindings
ii libboost-mpi1.53-dev 1.53.0-3 amd64 C++ interface to the Message Passing Interface (MPI)
ii libboost-mpi1.53.0 1.53.0-3 amd64 C++ interface to the Message Passing Interface (MPI)
ii libboost-program-options1.53-dev 1.53.0-3 amd64 program options library for C++
ii libboost-program-options1.53.0 1.53.0-3 amd64 program options library for C++
ii libboost-python1.53-dev 1.53.0-3 amd64 Boost.Python Library development files
ii libboost-python1.53.0 1.53.0-3 amd64 Boost.Python Library
ii libboost-random1.53-dev 1.53.0-3 amd64 Boost Random Number Library
ii libboost-random1.53.0 1.53.0-3 amd64 Boost Random Number Library
ii libboost-regex1.53-dev 1.53.0-3 amd64 regular expression library for C++
ii libboost-regex1.53.0 1.53.0-3 amd64 regular expression library for C++
ii libboost-serialization1.53-dev 1.53.0-3 amd64 serialization library for C++
ii libboost-serialization1.53.0 1.53.0-3 amd64 serialization library for C++
ii libboost-signals1.53-dev 1.53.0-3 amd64 managed signals and slots library for C++
ii libboost-signals1.53.0 1.53.0-3 amd64 managed signals and slots library for C++
ii libboost-system1.53-dev 1.53.0-3 amd64 Operating system (e.g. diagnostics support) library
ii libboost-system1.53.0 1.53.0-3 amd64 Operating system (e.g. diagnostics support) library
ii libboost-test1.53-dev 1.53.0-3 amd64 components for writing and executing test suites
ii libboost-test1.53.0 1.53.0-3 amd64 components for writing and executing test suites
ii libboost-thread1.53-dev 1.53.0-3 amd64 portable C++ multi-threading
ii libboost-thread1.53.0 1.53.0-3 amd64 portable C++ multi-threading
ii libboost-timer1.53-dev 1.53.0-3 amd64 C++ wall clock and CPU process timers
ii libboost-timer1.53.0 1.53.0-3 amd64 C++ wall clock and CPU process timers
ii libboost-wave1.53-dev 1.53.0-3 amd64 C99/C++ preprocessor library
ii libboost-wave1.53.0 1.53.0-3 amd64 C99/C++ preprocessor library
ii libboost1.53-all-dev 1.53.0-3 amd64 Boost C++ Libraries development files (ALL)
ii libboost1.53-dev 1.53.0-3 amd64 Boost C++ Libraries development files
