19
There's obviously a way to check to see when an update is a security update. I often get greeted by a motd that says "there are N security updates."
What I'd like to do is have my server email me a list of what packages need updating for security reasons.
To take it a step further, the email would link to the applicable security notification from Ubuntu.
Basically, each server is somewhat unique. I've received several emails on the security mailing list for packages I do not have install on any/all servers. So I'd like each individual server to tell me what it needs. That way I can apply updates in a timely manner, while avoiding restarting services like Apache that would cause users to have some downtime.
How could I do this?
David R.
  • 547
You can use tool called apticron to notify you when new updates are available. It sends you e-mail about pending upgrades, also giving you a choice to only send you e-mail about updates not previously notified.
To setup apticron edit /etc/apticron/apticron.conf and change line containing e-mail address:
EMAIL="admin@example.com"
Enter the e-mail address you wish to receive notifications to.
For more information see man apticron.
Mike
  • 5,931
From a previous post. you can run security upgrades via command line with.
sudo unattended-upgrade
I checked it out and you can also use the command line option
 sudo unattended-upgrade --dry-run
To download but not install updates.
When running the program I am not getting any output, I think this is because I have my system set to auto-update. If you can get output from this just figure out what the updated vs. pending updates look like and write a shell script to send you an email containing of the output of the pending updates.
Then run this script as a cron job.
Note: use crontab -e to run jobs as root.
tweirick
  • 152
According to: https://ubuntu.com/server/docs/package-management
Configuring Unattended-Upgrade::Mail in /etc/apt/apt.conf.d/50unattended-upgrades will enable unattended-upgrades to email an administrator detailing any packages that need upgrading or have problems.
I would assume that this would combine with your setting of scoping security updates only.
