It's astonishingly hard to find out how to install opengl headers on ubuntu. I've seen pointers to the opengl registry: http://www.opengl.org/registry/ but the files do not appear to be there.
I've also see reference that the files come in the nvidia drivers. Of course, the drivers supposedly are pre-loaded on the distribution, but perhaps not the developer tools.
If anyone on Ubuntu is listening, this is kind of a ludicrous situation. This is not wildly exotic stuff, loading the graphics libraries should be fast and easy. In fact, I might venture to suggest that these header files be included with any standard developer headers.
Anyway, I was trying to install the NVIDIA drivers with:
sudo sh ./NVIDIA-Linux-x86_64-260.19.12.run
This fails because the x server is running. I want to shut down, but if I kill it, it will just restart. I tried init 1 and it didn't work. This seems more complicated than it used to be, but I'm just not used to this distribution, any hints?
Thanks!
user.dz
  • 49,176
Dov
  • 833
You have to switch system to lower runlevel. By default, X starts in runlevel 5. Follow this article: Debian and Ubuntu Linux Run Levels | Debian Admin
you can change runlevel at runtime by executing e.g.init <n> or while booting by appending the number of runlevel to the grub boot string.
Fiisch
  • 227
Please have a look How to correctly install an Nvidia video card to know different kind of installation.
If you are keen to use .run file.
Press alt+ctrl+F1
Execute sudo stop lightdm
Now navigate to the downloaded file directory using cd.
Run the .run file using
260.19.12 seems pretty old driver, have you checked what is the latest version for your card.
Web-E
  • 21,716
