I can't boot into Windows 7 from GRUB, or can't boot into Linux from Windows 7 I have 2 HDD, on 1 I have Windows 7 and on other I have Linux. Both HDD are working properly.
Help me to correct dual boot.
Boot Info Script e7fc706 + Boot-Repair extra info      [Boot-Info 31Jan2013]
============================= Boot Info Summary: ===============================
 => Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sda.
 => Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    in partition 1 for (,msdos1)/grub.
 => Grub2 (v2.00) is installed in the MBR of /dev/sdc and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and uses an
    embedded config file:
    search.fs_uuid cb0e9d75-552c-4509-b720-d914e2375b4c root hd1,msdos1
    set prefix=($root)/grub
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 7/2008: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
    File system:       ntfs
    Operating System:  Windows 7
    Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda3: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sda5 starts
                       at sector 2048.
    Operating System:
    Boot files:
sda6: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sda6 starts
                       at sector 2048.
    Operating System:
    Boot files:
sdb1: __________________________________________________________________________
    File system:       ext3
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:        /grub/grub.cfg /grub/i386-pc/core.img
sdb2: __________________________________________________________________________
    Boot sector type:  Unknown
    Boot sector info:
sdb5: __________________________________________________________________________
    File system:       ext3
    Boot sector type:  -
    Boot sector info:
    Operating System:  Ubuntu 12.10
    Boot files:        /etc/fstab
sdb6: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sdb7: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sdc1: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1               2,048       206,847       204,800   7 NTFS / exFAT / HPFS
/dev/sda2    *        206,848   272,631,807   272,424,960   7 NTFS / exFAT / HPFS
/dev/sda3         272,631,808   639,633,407   367,001,600   7 NTFS / exFAT / HPFS
/dev/sda4         639,633,408 1,953,521,663 1,313,888,256   f W95 Extended (LBA)
/dev/sda5         639,635,456 1,059,065,855   419,430,400   7 NTFS / exFAT / HPFS
/dev/sda6       1,059,067,904 1,953,521,663   894,453,760   7 NTFS / exFAT / HPFS
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
/dev/sdb1    *          2,048       976,895       974,848  83 Linux
/dev/sdb2             978,942   301,758,463   300,779,522   5 Extended
/dev/sdb5             978,944    49,805,311    48,826,368  83 Linux
/dev/sdb6          49,807,360   293,945,343   244,137,984  83 Linux
/dev/sdb7         293,947,392   301,758,463     7,811,072  82 Linux swap / Solaris
Drive: sdc _____________________________________________________________________
Disk /dev/sdc: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
/dev/sdc1    *             63   488,392,064   488,392,002   7 NTFS / exFAT / HPFS
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/sda1        323AD4403AD3FF33                       ntfs       System Reserved
/dev/sda2        EC44E6E344E6AF8E                       ntfs       Windows 7
/dev/sda3        6C2478182477E38C                       ntfs       Softwares
/dev/sda5        54B6B371B6B351EA                       ntfs       Games
/dev/sda6        3A04C1F004C1AF67                       ntfs       Movies
/dev/sdb1        6570258e-4efb-4cdb-91af-5bd97ff51912   ext3
/dev/sdb5        543b5815-ffa5-4c88-b172-98587aca26ee   ext3
/dev/sdb6        083db3df-5599-4f0b-94d6-1d6ea52ece6e   ext4
/dev/sdb7        92d881dc-4a65-4b0a-aeac-62661734083b   swap
/dev/sdc1        AAD80849D80815EB                       ntfs       Other
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/sda3        /media/Softwares         fuseblk    (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sda5        /media/Games             fuseblk    (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sda6        /media/dhananjay/Movies  fuseblk    (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sdb5        /                        ext3       (rw,errors=remount-ro)
/dev/sdb6        /home                    ext4       (rw)
/dev/sdc1        /media/Other             fuseblk    (rw,nosuid,nodev,allow_other,blksize=4096)
Aryo Adhi
  • 1,397
  • 15
  • 41
dhanu
Try using these commands. They help fix many dual-boot issues like yours.
sudo os-prober; sudo update-grub
