I'm trying to find out the default ownership & permissions for my ubuntu install. I'm also trying to figure out whether the wrong-headed granted of file ownership to the user robert to system files is an irrecoverable error. Is it too complicated to try to undo what I have done for my system and just reinstall?
First, some background. I think I made the wrong command when I was trying to change the permissions on a 2nd ext4 drive which formerly had ubuntu installed on it. I must have inadvertently made changes to my current / directory without realizing it. Symptoms of the problem is that I no longer have sudo access on my current system.
robert@robert-KJ379AA-ABA-a6400f:/$ sudo ls -al
sudo: /etc/sudoers is owned by uid 1000, should be 0
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
I see that "robert" now owns all the files inside /etc: Examples:
drwxr-xr-x   3 robert root    4096 Apr  9 12:27 firefox
drwxr-xr-x   4 robert root    4096 Aug 23  2012 fonts
drwxr-xr-x   3 robert root    4096 Aug 23  2012 foomatic
-rw-r--r--   1 robert root     766 Apr 11 12:39 fstab
-rw-r--r--   1 robert root     664 Apr  9 11:26 fstab~
drwxr-xr-x   2 robert root    4096 Mar 29  2012 fstab.d
-rw-r--r--   1 robert root     664 Apr 11 12:36 fstab.original
-rw-r-----   1 robert fuse     216 Oct 18  2011 fuse.conf
-rw-r--r--   1 robert root    3343 Apr 19  2012 gai.conf
drwxr-xr-x   5 robert root    4096 Aug 23  2012 gconf
Here are the permissions and ownership for the / directory
drwxr-xr-x  25 root   root    4096 May  5 15:26 .
drwxr-xr-x  25 root   root    4096 May  5 15:26 ..
drwxr-xr-x   2 robert root    4096 Apr 10 22:55 bin
drwxr-xr-x   3 robert root    4096 May  5 15:26 boot
drwxr-xr-x   2 robert root    4096 Apr  9 11:30 cdrom
drwxr-xr-x  15 root   root    4560 May  5 17:28 dev
drwxr-xr-x 150 robert root   12288 May  5 17:45 etc
drwxr-xr-x   3 robert root    4096 Apr  9 11:37 home
lrwxrwxrwx   1 robert root      33 May  5 15:26 initrd.img -> /boot/initrd.img-3.2.0-41-generic
lrwxrwxrwx   1 robert root      33 Apr  9 12:26 initrd.img.old -> /boot/initrd.img-3.2.0-40-generic
drwxr-xr-x  22 robert root    4096 Apr 24 16:58 lib
drwxr-xr-x   2 robert root    4096 Apr 24 16:58 lib64
drwx------   2 robert root   16384 Apr  9 11:26 lost+found
drwxr-xr-x   5 root   root    4096 May  5 17:28 media
drwxr-xr-x   2 root   root    4096 Apr 19  2012 mnt
drwxr-xr-x   2 root   root    4096 Aug 23  2012 opt
dr-xr-xr-x 198 root   root       0 May  5 12:26 proc
drwx------   8 root   root    4096 Apr 17 02:11 root
drwxr-xr-x  23 root   root     820 May  5 17:43 run
drwxr-xr-x   2 root   root    4096 Apr 24 16:58 sbin
drwxr-xr-x   2 root   root    4096 Mar  5  2012 selinux
drwxr-xr-x   2 root   root    4096 Aug 23  2012 srv
drwxr-xr-x  13 root   root       0 May  5 12:27 sys
drwxrwxrwt  10 root   root    4096 May  5 19:37 tmp
drwxr-xr-x  10 root   root    4096 Aug 23  2012 usr
drwxr-xr-x  14 root   root    4096 May  5 17:26 var
lrwxrwxrwx   1 root   root      29 May  5 15:26 vmlinuz -> boot/vmlinuz-3.2.0-41-generic
lrwxrwxrwx   1 root   root      29 Apr  9 12:26 vmlinuz.old -> boot/vmlinuz-3.2.0-40-generic
drwxrwxr--   1 robert robert  4096 Apr  9 01:37 windows1
Can anyone confirm that "robert" must not own any of these directories just below root? Is there anything here to suggest that the problem may be easy to recover from? If yes, do you have any advice or resources for how to fix this? Thanks.
Zanna
  • 72,312
To make root owner of everything in /etc:
sudo chown root:root -R /etc
You will need to boot a live cd and run
sudo chown root:root -R /media/$USER/*/etc
You will need to open the folder in the file browser to mount the disk
Zanna
  • 72,312
Run below command:
pkexec chown root:root -R /etc
Now write your password.
Braiam
  • 69,112
Your best bet is to re-install all packages and let that fix your permissions for you. This will take some time, but it's the only way to fix everything.
sudo apt-get --reinstall install $(dpkg --get-selections | grep install | grep -v deinstall | cut -f1)
You can see more about this on this site, including some fixes for common problems with running that command.
Keep in mind you will want to reboot as soon as the command finishes or weird things will (or at least could) happen with different versions of libraries.
Zanna
  • 72,312
coteyr
  • 18,724
Well just run these commands
pkexec apt-get install sudo
then
pkexec chmod 0440 /etc/sudoers.d/README
And that's it
Zanna
  • 72,312
Ahmad
  • 101
