I installed Nitro using apt-get. However, it is dependent of gir1.2-launchpad-integration-3.0 and is missing. How can I get the source code of gir1.2-launchpad-integration-3.0 somehow and install it on my computer?
~$ sudo apt-get install nitro
Reading package lists... Done
Building dependency tree
nitro : Depends: gir1.2-launchpad-integration-3.0 but it is not installable
It does not work if you want to try to install it at the Ubuntu Application Store.
