I've tried to connect to a server via wget:
wget http://<user>:<pass>@serveradress
But wget responds: invalid port
I know that the server accepts incoming traffic at port 80. How can I fix this issue?
Wget interprets <pass>@serveraddress as port. To specify a username and password, use the --user and --password switches:
wget --user user --password pass http://example.com/
From man wget:
--user=user
--password=passwordSpecify the username user and password password for both FTP and HTTP file retrieval. These parameters can be overridden using the
--ftp-userand--ftp-passwordoptions for FTP connections and the--http-userand--http-passwordoptions for HTTP connections.
You have 3 options here. They are in no specific order other than gut feeling:
history)wget --user=remote_user --password=SECRET ftp://ftp.example.com/file.ext
The password will also be visible in ps, top, htop and similar.
Notice the white space before the command, it prevents saving it to your history.
The password will also be visible in ps, top, htop and similar. (Thanks user412812)
wget --user=remote_user --ask-password ftp://ftp.example.com/file.ext
Then you're asked for the password
Password for user `remote_user':
You can also store the username and password in the file ~/.wgetrc
and change the permissions of that file so that only your user can
read it:
File ~/.wgetrc:
user=john
password=SEcrEt
... and then
chmod 600 ~/.wgetrc
Note, however, that user root can still peek into that file and
read the password.
From the manpage:
To prevent the passwords from being seen, use the
--use-askpassor store them in.wgetrcor.netrc, and make sure to protect those files from other users with"chmod". If the passwords are really important, do not leave them lying in those files either --- edit the files and delete them after Wget has started the download.
This should work (don't miss the quotes)
wget 'http://<user>:<pass>@<serveradress>/<path>/<filename>'
Example for my access to the builds on ftp server
wget 'ftp://DOMAIN\thomas:dasbleibtgeheim@build.server12321.dd/download/bins/lastnightly_v1.2.3.bin'
Note: To avoid to get this in your shell history add a space in front of wget --> wget
You can provide authentication credential via --user=USERNAME and --password=PASSWORD; based on the man wget, the command can be overridden using the --http-user=USERNAME and --http-password=PASSWORD for http connection and the --ftp-use=USERNAME and --ftp-password=PASSWORD for ftp connection.
