To those that can help,I am guessing that you have seen a variant of this problem many times before. However after doing my best to try to use the various fixes mentioned across various pages, I have finally given up!
The problem is that I cannot run unity - because I cannot install the legacy drivers properly in 13.04.
When I input sudo apt-get install fglrx-legacy step after doing the previous 3 steps (which seem to run fine) I get the following output:
$ sudo apt-get install fglrx-legacy
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
fglrx-amdcccle-legacy fglrx-legacy-dev
The following NEW packages will be installed
fglrx-amdcccle-legacy fglrx-legacy fglrx-legacy-dev
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/72.4 MB of archives.
After this operation, 24.6 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Selecting previously unselected package fglrx-legacy-dev.
(Reading database ... 201264 files and directories currently installed.)
Unpacking fglrx-legacy-dev (from .../fglrx-legacy-dev_2%3a8.97.100.7-makson1~raring2_amd64.deb) ...
Unpacking fglrx-legacy (from .../fglrx-legacy_2%3a8.97.100.7-makson1~raring2_amd64.deb) ...
One or more files have been altered since installation.
Uninstall will not be completed. See /etc/ati/fglrx-uninstall.log for details.
dpkg: error processing /var/cache/apt/archives/fglrx-legacy_2%3a8.97.100.7-makson1~raring2_amd64.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
Selecting previously unselected package fglrx-amdcccle-legacy.
Unpacking fglrx-amdcccle-legacy (from .../fglrx-amdcccle-legacy_2%3a8.97.100.7-makson1~raring2_amd64.deb) ...
Any help is much appreciated. I am an Ubuntu noob. Thanks.
