13
Since Evince doesn't work with *.eps on 13.04 (see bellow), is there any other app to quickly open (not edit) a *.eps file?
petr@sova:~$ evince histogram_default.eps
undefined -21
undefined -21
(evince:12208): EvinceDocument-CRITICAL **: ev_document_misc_pixbuf_from_surface: assertion `surface' failed
(evince:12208): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
mreq
  • 4,932
Try using ghostscript from the command line. This has worked for me. It may need to be installed from the repositories if not present on your system. sudo apt-get install ghostscript or the equivalent.
belacqua
  • 23,540
Actually, this is a bug of Ghostscript.
https://bugs.launchpad.net/ubuntu/+source/evince/+bug/1159931 http://bugs.ghostscript.com/show_bug.cgi?id=693843
It has a problem dealing with the decimal separator "," in some locales. To workaround you can start evince like this:
LANG=en_US evince my_file.ps
