10
I have just upgraded my computer from ubuntu 12.10 to ubuntu 13.04, and now when I go to turn off my computer, it will not shut down fully. The Power supply keeps running, even when it is "off" Any suggestions please?
Max Tither
  • 1,354
Paul
  • 101
13 Answers13
I modified the script responsible for sending the kill signal with allocated delay, /etc/init.d/sendsigs, and reduce the amount of time it does to kill the remaining processes in 2 iteration. Healthy or not it gets the job done on my system and is no longer hanging on shutdown and restart.
Below is a portion of the /etc/init.d/sendsigs with modification indicated by # <--- :
# Kill all processes.
log_action_begin_msg "Asking all remaining processes to terminate"
killall5 -15 $OMITPIDS # SIGTERM
log_action_end_msg 0
alldead=""
OMITPIDS0="$OMITPIDS"
#for seq in 1 2 3 4 5 6 7 8 9 10; do  # this is the original line
for seq in 1 2; do     # <--- the above line is replaced by this one.
then on the lower part of the script:
# Upstart has a method to set a kill timeout and so the job author
# may want us to wait longer than 10 seconds (as in the case of
# mysql). (LP: #688541)
# We will wait up to 300 seconds for any jobs in stop/killed state.
# Any kill timeout higher than that will be overridden by the need
# to shutdown. NOTE the re-use of seq from above, since we already
# waited up to 10 seconds for them.
while [ -n "$(upstart_killed_jobs)" ] ; do
    seq=$(($seq+1))
    #if [ $seq -ge 300 ] ; then # this is the original line
    if [ $seq -ge 2 ] ; then   # <--- I can't wait for another 300 iteration
        break
    fi
NOTE: This may not be the best solution since the original script is working on other systems, for those systems like mine where several suggested solutions did not apply - this is what I can share considering I am only running the system as a workstation with no critical services running after closing all the desktop applications I use before clicking on the shutdown or restart icon.
System in use is an Asus X550DP laptop.
Braiam
  • 69,112
Vernie
Try the command
sudo shutdown -P now
in the terminal.
If even after broadcast, the state remains active, then force shutdown by holding the power key pressed for 5 seconds reboot and go to
/etc/default/halt
and forcefully add
INIT_HALT = power_off
(as pointed by mauro above) this must work again with the normal shutdown or shutdown from the terminal.
MadMike
  • 4,275
  • 29
  • 50
ProgWiz
it might be a bug.Please check the link below:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1010981
rishab v
  • 111
I had the same trouble with my Macbook Pro running Ubuntu 13.04. After some tries and worries, I found a workaround. Does your computer run with 2 CPUs or more? In my case I had to edit the GRUB2 config file in order to add the parameter MAXCPUS=1 (and get rid of ACPI=OFF).
greguti
  • 545
I've seen problems with this and 'Modem Manager' which is installed by default.
Unless you are using a modem, which these days is unlikely, you can
sudo apt-get remove modemmanager
See my comment about viewing the progress of shutdown.
Jay M
  • 215
Try running this command in terminal sudo shutdown -h now Guess that should help.
enter terminal, and type "sudo shutdown -p now". If your system still hangs on shutdown, you could always do it the hardware way, and hold your power button down for 5-10 seconds, and force the system to shutdown without getting an error or "Unexpected shutdown".
Try opening Terminal and typing sudo shutdown now or sudo poweroff. You will need to enter your administrator password.
Braiam
  • 69,112
Check your BIOS if ACPI is enabled. ACPI is the Advanced Configuration and Power Interface and is used to tell the different devices in your computer to shut down (or not). In this case it seems that the OS is installed with ACPI enabled and later is was disabled. I assume the signal is send to the BIOS to shut down, but the BIOS does not send the signal to the different devices...
The opposite is also possible (OS installed with ACPI enabled and later it is disabled).
phulstaert
  • 51
Try adding
INIT_HALT=poweroff
to
/etc/default/halt
this worked for me in 13.10
In addition to the answers already given:
  • Try Pressing the Esc button during the shutdown when 'Ubuntu' appears on the screen to enable terminal messaging (if ESC does nothing, try F1, F2, or combining these keys with Alt, Ctrl and Left Shift).
    Observe where the system appears to be hanging or too slow, and state what messages were shown at the time.
  • Try the following command from a terminal screen:
    sync; sudo -P shutdown now
    If shutdown is faster, then you probably have a several asynchronous disk writes waiting to be committed when you shutdown.
    If so, you can limit this by placing commit=xx in the fstab options for the affected filesystem (with xx being the number of seconds between committing disk writes).
rask004
  • 131
Like many has suggested, I used the terminal console, but for many who I have introduced Linux, the black terminal screen scares them.
I found an alternative that also works. I install cairo-dock which has a shutdown button. So far that one has worked when the regular shutdown failed.
L. D. James
  • 25,444
Just do:
sudo poweroff
or logout and then choose power off.
