Failed to parse arguments: Argument to "--command/-e" is not a valid command: Text ended before matching quote was found for ". (The text was '"cpulimit')
this is what i get when i run the following script in terminal
    #!/bin/bash
read -p "Which program u want to limit its processes?" ProgrameName
read -p "Which limitation percentage u want for it ?" limitationPercentage
getAllPIDRunUnderThisProgram=$( ps -e | grep "$ProgrameName" | awk '{print $1;}')
for i in $getAllPIDRunUnderThisProgram
   do
    gnomeTab+="  --tab -e \"cpulimit -p $i -l $limitationPercentage \" "
   done
gnome-terminal $gnomeTab
he cant parse the escape character "\" which it has to be used because of the double quote in line 8 gnomeTab+=" --tab -e \"cpulimit -p $i -l $limitationPercentage \" ",so is there a solution to use the double quote as they are mandatory to be used after --tab -e " some commands " and not to get the problem of parsing ?
Ahmed Zain El Dein
  • 634
  • 25
You can change the very first line to
#!/bin/bash -xv
to make the shell show you how it interprets arguments.
Rather than escaping (which leads to eval), you should use arrays to accumulate options:
for i in $getAllPIDRunUnderThisProgram ; do
    gnomeTab+=(--tab -e "cpulimit -p $i -l $limitationPercentage")
done
echo "${gnomeTab[@]}"
choroba
  • 10,313
