  • I have Intel Centrino Wireless-N 1000
  • I installed hostapd from Ubuntu Software Center
  • When I run this command hostapd hostapd-minimal.conf I get this:
    root@tarek-PC:~# hostapd hostapd-minimal.conf
    Configuration file: hostapd-minimal.conf
    Line 2: invalid/unknown driver 'nl80211 '
    Line 4: unknown hw_mode 'g '
    2 errors found in configuration file 'hostapd-minimal.conf'
After doing make first I had this error:
driver_nl80211.c:25:26: warning: netlink/attr.h: No such file or directory
I solved it by installing libnl-1.0pre8
Now I have this error when doing make command:
../src/crypto/crypto_openssl.c:10:30: fatal error: openssl/opensslv.h: No such file or directory
compilation terminated.
make: *** [../src/crypto/crypto_openssl.o] Error 1
Can anyone help me with that error I am running Ubuntu 13.04?
techraf
  • 3,316
Tarek
  • 107
You need to build, or obtain, a different copy of hostapd. The one you have has been built with the option CONFIG_DRIVER_NL80211 set to N, rather than Y.
There are simple and detailed instructions how to rebuild it here → Hostapd building instruction. Rebuild it with the option enabled. You may have to google for hostapd.2.0.tar.gz, but do exactly as it mentioned in link.
As for the follow-up question/error try to install this library libssl-dev using this command:
sudo apt-get install libssl-dev
muru
  • 207,228
pourjour
  • 229
You see the spaces after the values? Remove them.
  • Line 2: invalid/unknown driver 'nl80211 '
  • Line 4: unknown hw_mode 'g '
Seth
  • 59,332
jmarcos
  • 51
Check for EOL format. It should be in UNIX format as < LF > and not < CR >< LF >. That fixed mine error.
Dmitrij
I had a similar Problem, but without the spaces after the values and managed to solve it:
Before I encountered the Problem, I copied the hostapd.conf file from my Windows pc onto my Raspberry Pi. And I believe the problem was, that the text had special characters. Maybe some returns were different (Because I had a return instead of a space after the values in the errors)
But enough speculation, let's come to my solution:
  1. I renamed the old hostapd.conf file (to hostapdOld.conf)
  2. I created a new file with the name hostapd.conf
  3. And then I copied the whole content of the old file to the new one. (I just selected the whole text, didn't use Ctrl+A, if this even matters)
Then I ran hostapd as usual, with:
sudo hostapd -d /etc/hostapd/hostapd.conf
And it worked again
