15
I just installed Rabbitvcs on ubuntu 13.04 as per the official instructions. When i tried to install apt-get install rabbitvcs-nautilus3, i got the following error message :
Reading package lists... Done
Building dependency tree
Package rabbitvcs-nautilus3 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
rabbitvcs-nautilus
E: Package 'rabbitvcs-nautilus3' has no installation candidate
So i installed it with apt-get install rabbitvcs-nautilus, and now rabbitvcs options are not showing when i right click on a folder. Any help and suggestions will be highly appreciable. Thanks.
LX7
  • 371
9 Answers9
12
I added the below symlinks
sudo ln -sf /usr/lib/i386-linux-gnu/libpython2.7.so.1 /usr/lib/libpython2.7.so.1
sudo ln -sf /usr/lib/libpython2.7.so.1 /usr/lib/libpython2.7.so.1.0
and replaced the /usr/share/nautilus-python/extensions/RabbitVCS.py with RabbitVCS.py
Now its working fine for me. :)
LX7
  • 371
$ sudo ln -sf /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 /usr/lib/
$ sudo ln -sf /usr/lib/x86_64-linux-gnu/libpython2.7.so.1 /usr/lib/
plus downloading RabbitVCS.py's new version helped on my x64 installation. This file need to be copied to /usr/share/nautilus-python/extensions/RabbitVCS.py using root/su/sudo
NGRhodes
  • 9,680
I had the same problem but not from a fresh install, from an upgrade from 12.10.
The nautilus graphical interface of RabbitVCS is not working.
I raised a ticket with the RabbitVCS developers. You can monitor it here, in case a solution is found:
https://code.google.com/p/rabbitvcs/issues/detail?id=803&q=13.03&colspec=Stars%20ID%20Type%20Status%20Priority%20Milestone%20Owner%20Summary
Thanks,
Yannis
I know this has been answered already, but here are my steps in order to fix the problem on Xubuntu 13.04:
Firstly, I replaced /usr/share/nautilus-python/extensions/RabbitVCS.py with RabbitVCS.py.
Then in the terminal run:
sudo ln -s /usr/lib/x86_64-linux-gnu/libpython2.7.so /usr/lib/libpython.2.7.so
sudo ln -s /usr/lib/x86_64-linux-gnu/libpython2.7.so.1 /usr/lib/libpython.2.7.so.1
sudo ldconfig
killall nautilus
nautilus
If this doesn't work for you, then you can find out which libraries RabbitVCS could not find by running:
nautilus --no-desktop -q
Related (and potentially useful):
Just restart nautilus. Sometimes it's working in background to show the desktop icons (this is my case).
Solution:
sudo killall nautilus
Enjoy!
kiri
  • 28,986
PabloRQ
  • 199
In my Ubuntu 13.04 raring x86 - I solved
sudo ln -sf /usr/lib/i386-linux-gnu/libpython2.7.so.1.0 /usr/lib/libpython2.7.so.1.0
killall nautilus
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
On Ubuntu 13.10, the above suggestions have been helpful. Although it seems like sometimes they work and sometimes don't for me. Many times I still don't get the right-click context menu to show SVN/Git stuff. Then after doing...
I noticed that there was a permission issue with /home/[me]/.config/rabbitvcs - and it turns out it was owned by root (probably because I used sudo while doing something to install rabbitvcs), so when I changed it to be me again, I got my context menu working after a nautilus restart
Just thought this might help someone
If you do not have libpython2.7.so.1.0 into /usr/lib/i386-linux-gnu then you can install it by using sudo apt-get python2.7. After installing just reboot your system or restart your nautilus.If this still not solve your problem then install rabbitvcs-thunar into your system.
-1
The problem was related to the permissions for me also. When (on my Ubuntu 12.04 32b) I added a new user, the rabbitvcs stopped to work on the first user. I solved the problem deleting the .config/rabbitcsv directory and restarting the nautilus.
fgiava
