A simple way to fix Acer Aspire 4736z back light brightness control problem using hot keys (Fn + Brightness +-)
            Asked
            Active
            Viewed 3,285 times
            Open up the terminal and type
sudo -H gedit /etc/default/grub
Find this line:
GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash"
Replace the line with this:
GRUB_CMDLINE_LINUX_DEFAULT="acpi_osi=Linux acpi_backlight=vendor"
Save the changes and close the editor then come back to the terminal and enter the below command to update the GRUB configuration:
sudo update-grub
Just reboot the machine.
        Zanna
- 72,312
        Danial José
- 336
