Today I installed the linux 3.9 Kernel update (because I heard it would fix sound through HDMI which I no longer have since installing 13.04). After restarted my computer and logging in my screen has only a desktop, and no dock or tool bar.
I tried to reset unity and compiz using guides like this one but nothing happens, even after reboot.
Is there any way to downgrade or reset the update?
EDIT: Running uname -a in terminal brings up 3.8.0 as my current kernel for some reason.
Jorge Castro
  • 73,717
David
  • 33
The old kernel should still be installed unless you manually removed it. On the Grub screen there should be an option to view old kernels and boot using them. If you're able to successfully boot using an old kernel you can then file a bug report and work on figuring out what went wrong. Or you can uninstall the new one and then run:
update-grub
To make Grub rescan the available kernels. That should return everything to before the kernel update, if not comment and I'll update with something more drastic.
japzone
  • 1,283
