-1
I have a drive of 250 gb which i had partitioned into two. 180 gb had a lot of music. It was my lifetime's collection of music. the other 50 gb had windows installed in it and also had Ubuntu 12.10 on it. Now, I uninstalled Ubuntu using wubi and now tried to install ubuntu 13.04.
I selected 7 gb of partition during the installation for ubuntu and 1 gb for swap data. I remember vividly when I was doing the partition, i selected the new partition table option and it showed me 250 gb. I re-partitioned it to 7 gb and added one more gb for swap data. After installing, i have lost the entire 250 gb of data. all my music and windows 7 also is gone. When i go to disks and check, there is a 242 gb of unallocated space shown. I really really want my data as it contains a lot of music and im a musician.
I tried testdisk and it didnt recover anything. Can you guys help? I'm desperate here.
bain
  • 12,200
Lost Partition
If you made a mistake while partitioning and the partition no longer appears in the partition table, so long as you have not written data in that space, all your data is still there.
GNU Parted
Run Parted from the command line to recover your partition.
When changing the partition table on your hard drive, you must ensure that no partition on the disk is mounted. This includes swap space. The easiest way to accomplish this is to run the live cd. Parted is installed on the base Ubuntu system. Once at the desktop, open a terminal and run_:
sudo swapoff -a
Next run parted and tell it to use the device in question. For example, if your /dev/sda drive is the drive from which you want to recover, run:
sudo parted /dev/sda
Then, use the rescue option:
rescue START END
where Start is the area of the disk where you believe the partition began and END is its end. If parted finds a potential partition, it will ask you if you want to add it to the partition table.
mreq
  • 4,932
