11
Due to compatibility bugs between Plex server and Panasonic TVs, the only way to get it to work well is remux everything to MKV, straight copy all streams (video, audio, subtitle)
Seems simple enough:
avconv -i "input.avi" -c copy "output.mkv"
Except:
avconv version 0.8.6-4:0.8.6-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
  built on Apr  2 2013 17:00:59 with gcc 4.6.3
[mpeg4 @ 0x8422140] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'input.avi':
  Metadata:
    encoder         : VirtualDubMod 1.5.4.1 (build 2117/release)
  Duration: 00:27:38.52, start: 0.000000, bitrate: 1173 kb/s
    Stream #0.0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 640x352 [PAR 1:1 DAR 20:11], 25 tbr, 25 tbn, 25 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 132 kb/s
File 'output.mkv' already exists. Overwrite ? [y/N] y
Output #0, matroska, to 'output.mkv':
  Metadata:
    encoder         : Lavf53.21.1
    Stream #0.0: Video: mpeg4, yuv420p, 640x352 [PAR 1:1 DAR 20:11], q=2-31, 1k tbn, 25 tbc
    Stream #0.1: Audio: libmp3lame, 48000 Hz, stereo, 132 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
Press ctrl-c to stop encoding
[matroska @ 0x8422cc0] Can't write packet with unknown timestamp
av_interleaved_write_frame(): Invalid argument
With the relevant gotcha lines being:
[mpeg4 @ 0x8422140] Invalid and inefficient vfw-avi packed B frames detected#
<snip>
I can't see an option to unpack the B frames (or build a VBR timemap? do we need those in avconv?)
Is there a way to do this, like in avidemux?
RoboJ1M
  • 732
A workaround is to convert to .mp4 first:
avconv -i input.avi -c copy temp.mp4
avconv -i temp.mp4 -c copy output.mkv
rm temp.mp4
Sadly, one cannot simply pipe the mp4 format between avconv instances: "[mp4 @ 0x80846c0] muxer does not support non seekable output"
rmsr
  • 141
As of this ticket #1979 at ffmpeg bugtracker the simplest solution is to have this bug fixed or to manually add -fflags +genpts to the command line.
I.e. change
ffmpeg -i inputfile_that_cant_be_muxed_into_mkv.ext -c copy out.mkv
to
ffmpeg -fflags +genpts -i inputfile_that_cant_be_muxed_into_mkv.ext -c copy out.mkv
erik
  • 667
Thanks to Andreas Cadhalpun ffmpeg now has new filter: mpeg4_unpack_bframes (see ref). This will allow you to get rid of the message: Invalid and inefficient vfw-avi packed B frames detected.
Usage is as simple as:
ffmpeg -i INPUT.avi -codec copy -bsf:v mpeg4_unpack_bframes OUTPUT.avi
malat
  • 471
