I've just installed ubuntu 13.04 on my notebook Compaq 6720s and found the cpu fun working at high speed after waking system up. When the system is booted the fan works normaly and realy calm. But after sleep and waking up fan is really noisy. I hadn't this problem with ubuntu 12.10. Any help appreciated.
Asked
Active
Viewed 7,691 times
I've found solution for my Compaq 6720s fan and Ubuntu 13.04 here:
Create the file ”/etc/pm/sleep.d/99fancontrol.sh”, insert the code below and chmod 755 it. Script:
#!/bin/sh
case "$1" in
hibernate|suspend)
# Stopping is not required.
thaw|resume)
# In background.
echo -n 0 > /sys/devices/virtual/thermal/cooling_device0/cur_state;
sleep 2
echo -n 0 > /sys/devices/virtual/thermal/cooling_device1/cur_state;
sleep 2
echo -n 0 > /sys/devices/virtual/thermal/cooling_device2/cur_state;
*) exit $NA
esac
Oleksii
- 56
For my "HP 2510p" is high fan speed everytime so I run it on start too:
cd /etc/init.d
ln -s {source_path}/99fancontrol.sh
update-rc.d 99fancontrol.sh defaults
Also device is set to multiple inputs "cooling_device0 ~ 6" - 6 is 30%, all to zero means 0% speed - and at the same time temperature controller works too so when temperature is high set on of these inputs automatically.
File: 99fancontrol.sh
#!/bin/sh
case "$1" in
hibernate|suspend)
start|thaw|resume)
sleep 5 ;
echo -n "0" > /sys/devices/virtual/thermal/cooling_device0/cur_state;
echo -n "0" > /sys/devices/virtual/thermal/cooling_device1/cur_state;
echo -n "0" > /sys/devices/virtual/thermal/cooling_device2/cur_state;
echo -n "0" > /sys/devices/virtual/thermal/cooling_device3/cur_state;
echo -n "0" > /sys/devices/virtual/thermal/cooling_device4/cur_state;
echo -n "0" > /sys/devices/virtual/thermal/cooling_device5/cur_state;
echo -n "1" > /sys/devices/virtual/thermal/cooling_device6/cur_state;
*) exit $NA
esac
Ref: Fabrizio
Bruno
- 190
- 1
- 6
